We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
I have custom Login page, It was assigning based on appkey.I need to check user name and password given in that and want to set session for successful credentials. Is it possible.I know the Thingworx form login but need customize my page according to my requirement.
Hi @ashok12391 I think you should be able to get all the required current session information via the available services in ThingWorx Composer > Resources > CurrentSessionInfo.
@supandey sorry my question is not clear, I want user name and password checking service in thingworx, I am implementing my own login exactly like Thingworx form login.Any ideas to achieve this
@ashok12391 if that is the case you might want to look into creating a custom Login Authentication, see more detail here. The documentation does cover sample configuration and other details on packaged used in developing the extension.
Once you have built your login authenticator extension it will have to be imported into ThingWorx and you will be required to provide it prioritisation when a user will attempt an authentication.
Hello @supandey
Thanks for the response, It was very helpful for me. Do we have any ready to use custom authentication functionality source code available in git or any where.If yes,Can you please provide me download link to get code.I dont have any coding knowledge in java to implement this.
@ashok12391 you could look into the Help Center document on General Development Process provided under the topic Authenticators in ThingWorx Help, together with Authenticator Sample Extension Cofiguration. Additionally there is a knowledge base article ThingWorx - Custom Authenticators Overview
There are not github samples at this moment.
