Hi, I want to change the color of the grid cell when it is updated
Sameera,
Use the RowFormat configuration to design how you want your grid to look based on values in the grid.
Here i have designed the style of the grid row based on the value of the property MVA. The grid will update as the property value changes.
as for a grid cell, i'm not sure we have the ability to do this yet. The new composer will allow us greater access using CSS and therefore i believe we might be able to achieve this kind of thing.
Hope it helps,
Andy
Sameera,
Hope it helps,
Andy
