Hello Developers,
I m trying to upgrade my running ThingWorxFoundationMSSQL-9.5.4-x64 on windows by using ThingWorx-Platform-Mssql-version-9-6-0 war file. I did all the steps which are mentioned on ptc page but it did not work.
So can anyone please help me to upgrade Thingworx?
Thanks.
Hi @Pratik_Aswale what steps are you following? and what error are you facing.
hi @Surya_Tiwari I follow the steps from below link-
And after this all steps I restart tomcat but after few second it will automatically stop.
Hello @Pratik_Aswale, in your ApplicationLog.log it clearly says that your ThingWorx version is still 9.5.4, not 9.6. So Tomcat didn't pick up that WAR file. Also, it seems that your ThingWorx was running for at least 20 minutes -- were you able to access Composer?
/ Constantine
Hi @Constantine Thanks for your replay. Got it .
Can you please share some simple steps to change war file and run upgraded Thingworx?
Here's the detailed steps. This may look like a lot of work, but most of the steps won't apply to you, so you'll just skip them. In essence, the process is
/ Constantine
It appears that your question, has received an answer. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
pehowe
If you have succeeded in you upgrade, Please post the step you followed and issue which you resolved.
In checking the the logs it does appear that you need to update the version of Java to 11.0.22 for use with ThingWorx 9.6.0
Pehowe
