i have services code but how to implement schedulers
me.SendMessage({
cc: "xxx@gmail.com" /* STRING */,
bcc: "yyy@gmail.com" /* STRING */,
subject: "this well"/* STRING */,
to: "hariharasuthan@yahoo.co.in" /* STRING */,
body: "this is verywell" /* HTML */
this services was running e-mail but i need (hour,day,week,month,year) this based how to implement schedulers concept
You can use 'Scheduler' Thing to trigger an event based on CRON String.
Based on the CRON String event will be triggered hourly, weekly, or Monthly
Step 1: Create a Scheduler Thing
Step 2: Configure CRON String
Step 3: Create a Subscription to trigger email
/ VR
/ VR
hi @Velkumar
i have completed step by step process as you suggested but i am unable to receive emails every five Minutes ,please let know any additional steps to do, i need one full example . Thank you .
Could you please show your CRON String?
Below CRON string should trigger the scheduler event every 5 min
0 */5 * ? * *
You can also use this link to generate CRON String
And could you please elaborate on your use case?
Everything looks good.
Please change your CRON String to
0 */5 * ? * *
If you want to trigger mail every 5 mins
Based on your CRON String event will be triggered every hour after 5 mins
And check whether the subscription is enabled
hi @Velkumar
please help me, i have learning stage thingworx developer. i plan to every five minutes sent mail .
step 1:
step 3:
Services
step 4:
Events
ADD -> new event created , event name:xxyy , datashape : one mapped
step 5:Subscriptions
Subscriptions name :xyz
source: me selected then Enable button click
input -> event->scheduledEvent ,then what do to
email code which place ,write code ,
me.SendMessage({
cc: "mmmm@gmail.com" /* STRING */,
bcc: "kkkk@gmail.com" /* STRING */,
to: "ppp@yahoo.co.in" /* STRING */,
please one E-mail example give me
i have done email sent, but how to implement scheduling.
Check this video
