import js library
Marble
import js library
Can anyone suggest me a way of connect to SignalR hub from thingworx?
Is this possible and if not what is the way to approach?
Re: import js library
Hello, Vijay.
I cannot find any documentation on connecting to SignalR to/from ThingWorx, or even a mention of it having been tried.
I take it you're trying to add an API library for it, and it fails? Is there an error that gets thrown?
-- Craig A.
Hi @vijay5.
Have you found a solution to your problem?  If so, we would love for you to post it here and mark it as the Accepted Solution for the benefit of others who may encounter the same issue.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
