making the google maps widget visible/invisible dynamically
tlichtenberger-
Hello everyone!
Currently I am working on two google maps widgets which are superimposed. The two google maps widgets are showing exactly the same locations, but
with different marker icons. What I want to do is to make the overlying google map visible/invisible based on the value of a boolean property which is defined in my helper thing.
In the following, I show you how I tried to realize that:
1) I have declared a boolean value named "IsVisible" that emits an event every time the value changes:
2) I have implemented a custom service which gets executed everytime a specific value has changed and sets the "IsVisible"-property to the correct value.
3) Then I have binded the event "ServiceInvokeCompleted" of my custom service with the imported service "GetBooleanPropertyValue" and have defined the
     needed PropertyName parameter as "IsVisible".
4) then I have binded the boolean Output of the function "GetBooleanPropertyValue" with the visible-property of the overlaying google maps widget.
Any suggestions on how to solve this problem?
Thank you so much in advance.
Best regards,
Theresa
Hi Theresa Lichtenberger​,
Here is workaround I thought for this issue:
Create two Duplicate Mashup but with different icons. Now when you want to change the icon navigate to other mashup i.e. bind navigate event of Navigate widget with the required event.
I hope it helps.
4 REPLIES 4
On what step are you facing issue?
hey @Ankit Gupta!
it seems that the map is just going gray instead of invisible.
Unfortunately, I do not exactly where the mistake could be. Maybe you have an other approach to solve this?
Thank you btw for your superfast answer. This is very much appreciated .
best wishes,
theresa
I checked this scenario on my local instance and I was able to reproduce this issue. It seems that Google map rendering happens on Mashup load and the invisible Map remains un-rendered.
Is there any specific reason to use two different marker icons for the same location. Could you please share use case in more detail?
I hope it helps.
