Invalid parameter type for service UpdatePropertyValues
jmay1
I am trying to implement the functionality from the following PTC article:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS256872&art_lang=en&posno=7&q=add%20values%20to%20value%20stre…
My code looks like this:
      var params = {
            infoTableName : "InfoTable",
            dataShapeName : "NamedVTQ"
        var value = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
        var prop = new Object();
        prop.name = "DailyPouchCount";
        prop.value = 29907;  //hardcoded for testing
        prop.time = endDate;      //DateTime object from input
        prop.quality = "GOOD";
        value.AddRow(prop);
        me.UpdatePropertyValues(value);
And I get the following error:
Wrapped java.lang.Exception: Invalid parameter type for service : [UpdatePropertyValues] on <ThingName> Cause: Invalid parameter type for service : [UpdatePropertyValues] on <ThingName>
Anyone have any idea why?
Thank you.
ankigupta
(To:jmay1)
Hi Jenna May​,
Following blog shoudl resolve your issue: How to use UpdatePropertyValues Service in ThingWorx
In the following line; the value infotable has be passed as part of JSON parameter
var params2 = {
    values: value /* INFOTABLE */
me.UpdatePropertyValues(params2);
ankigupta
(To:jmay1)
Hi Jenna May​,
var params2 = {
jmay1
(To:ankigupta)
That worked. Thank you!
ankigupta
(To:jmay1)
Hi Jenna May​,
Glad it was helpful.
