max size 500 for DeleteDataTableEntries ?
seanccc
Just found that DeleteDataTableEntries can only delete 500 entries as most , but there is no parameter to control it.  Executing the service one more time, and it will delete the next 500 entries.  Is it a correct/designed behavior ?
Thingworx version:  8.4.4
Sean
4 REPLIES 4
vangne
(To:seanccc)
@seanccc This is a known issue. The cause of this issue is
  • FindDataTableEntries() does not currently accept a maxItems parameter, and as such defaults to a limit of 500 results returned.
  • DeleteDataTableEntries() calls FindDataTableEntries() behind the scenes, and as such is subject to the same 500 result limit.
The solution to this issue has been provided in Thingworx 8.5
Vibhuti
PaiChung
22-Sapphire I
(To:seanccc)
There is a purge service available as well I believe. If you can define what you want to remove based on timestamp.
seanccc
(To:PaiChung)
@PaiChung ,
I need to remove by the data table's key,  not timestamp.
Sean
PaiChung
22-Sapphire I
(To:seanccc)
If you can't specify the maxItems parameter then the only way to do more than 500 is to do it in the persistence layer directly.
