modify the ID of a button in Thingworx?
rwen
1-Newbie
Is there a way to modify the button ID in Thingworx without exporting the mashup and changing it in the xml?
3 REPLIES 3
Aanjan
9-Granite
(To:rwen)
Robert, did you mean the ContextId? That can't be modified through the Composer.
rwen
1-Newbie
(To:Aanjan)
I actually meant the ID, but in your reply were you referring to the ContextID or the ID? Essentially there are no ways for me to change the ContextID and/or the ID in the composer is that correct?
posipova
20-Turquoise
(To:rwen)
You cannot change the ID, but for the ContextID - you may feed string to/from it by binding to a service or another widget (i.e, binding a textbox output to the input of the ContextID of a button)
