multi markers with google map extension
DD_7886593
2-Guest
Hi, I would like to insert geolocation positions into a google map in the mashup.
1/ I start to get the data from my service with output INFOTABLE
2/ I insert a googlemap widget into the mashup and I inseted all returned data into the googlemap widget:
Should I choose Location type from the data shape for the fields?
AdamR
(To:DD_7886593)
Hi David, you will need to convert the separate fields into a single location type field.  You can do this via service and using the following structure for location type...
var location = new Object();
location.latitude = 0;
location.longitude = 0;
location.elevation = 0;
location.units = "WGS84";
Adam
Hi Adam,
Could you check this with please :
I got this when I choose data shape type as location.
AdamR
(To:DD_7886593)
David,
Could you post (or message me) the service code?  Or is this coming from an external (to Thingworx) data source?  This would be the quickest way to assist.
Adam
