I'm trying to set up a connection to a MySQL database that I have. I've installed the JDBC Connector extension from the marketplace and that gave me the JdbcCreator and the JDBCExtentionCreator.
Following a tutorial it says to create a new thing and select MySqlServer as the thing template. However, I am unable to see a MySqlServer template.
Any ideas? Have I missed something?
Charlotte
If you use the relational one it has several packaged inside pull out the one you need and only install that one
Great, thank you!
Great, thanks!
