hello,
i need d3 tree extension zip file to design the d3 tree like below snapshot:-
please share the extension file asap
"ThingWorx Entity Export with Service to Create Example Hierarchical Data for Tree Widgets": https://community.ptc.com/t5/IoT-Tech-Tips/ThingWorx-Entity-Export-with-Service-to-Create-Example/m-p/533859
Hi @Ru.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
