need to send grid data from mashup into the e-mail
KSM
Amethyst
I have one requirement, I want to send the grid data to the user through e-mail. what is the feasible solution.
13 REPLIES 13
Re: need to send grid data from mashup into the e-mail
Just build and email with HTML Content and send it with the MailExtension
could you please elaborate little bit and if any sample code you have .
You just need to fill a String with the desired html format and send it with a Thing which derived MailServer ThingTemplate (that you will find on Marketplace Extension: https://marketplace.ptc.com/apps/193028/mail-extension )
var emailContent = "<html><body>\
 <table>\
  <tr><td>Column1</td><td>Column2</td></tr>\
  <tr><td>RowValue1</td><td>RowValue2</td></tr>\
</table></body></html>"
Things["YourMailServerThing"].SendMessage({
 to: "email_destination@anothermailserver",
 subject: "Awesome email, with a table :P",
 content: emailContent
Thanks carles, but for filling that content definitely we need to get that grid data into the service first, then only it will possible right?
Yes of course, you have to build a service which accepts the Infotable ( if you fill de Grid, you already have a service that fills the grid, just get this output and use it as input of the SendGridToEmail service ) and sends it through email.
Highlighted
Thx Carles,
I have binded the selected rows property of a grid to my service input which is of type infotable. now i want to check whether that input has that selected rows data or not, that how should I check. is it possible by setting logger.info or something else.
You have to bind from the right side ( service Selected Rows, the one that fills the grid) not from the Grid.
I have done but how can I check whether I got that infotable in my input or not?
logger.info("Number of rows "+yourInputInfotableName.rows.length);
