Right now I am working in a remote desktop. when i open the composer, sometimes it says no Things found and same goes for all the entities. what could be the reason for this?
Hello @Sruthi,
This often happens when you try to login with two different users in different tabs of your browser. Keep in mind that all tabs share the same user session.
/ Constantine
Are there any errors in Application.log?
Raluca Edu
application log was also not opening.
oh, ok thankyou
Hi @Sruthi.
If you feel that Constantine's response answered your question, please mark it as the Accepted Solution for the benefit of others on the community. If you are still having issues, please provide more details so we can try to assist.
--Sharon
