How do i drag pop up mashup over main mashup screen in runtime in thingworx 8.5.2?
I do not believe this behavior is present in our pop-up. But by setting it to 'not modal' you can move around the pop up and access the screen underneath.
If you want a pop up that can be moved in runtime, you need to have a Title on the pop up mashup, this will then show the title bar which can be grabbed and dragged.
I am able to drag the popup now.Thanks
Is there any option to minimize/maximize the popup by mouse click on borders?
