After purged all datas in valuestream, those datas are present in postgress database. It should be permenantly deleted right? Is there a option to retrive those purged datas again?
Hi Sometime if you dont give start and end date while purging value stream, entries may not get deleted
also check your logs for any errors..some time issues with persistence provide could be logged
The number of records should ideally get reduced after purging all data and I don't think it can be recovered.
Can you refresh the table and see if the count changes?
Sachin Sharma
If i didnt purged 10 days old datas in valuestream, the server is becoming slow. what is the actual storage of valuestream.?
