you can use a command like this:
"filters": {
"type": "EQ",
"fieldName": "CustomerId",
"value": 2
If necessary, use this older article as a guide for the parameters (TWX 8 doc):
"filters": {
"type": "EQ",
"value": 2
Iam getting error when i given this query. What is the mistake here. @M4RC
"filters":
"type": "AND",
"filters": [{
"type": "EQ",
"fieldName": "MachineName",
"value": MachineName
"type": "EQ",
"fieldName": "TaskName",
"value":oldTaskName
You can try this:
{"filters":
"type": "And",
"filters": [
"type": "EQ",
"value": "MachineName"
"type": "EQ",
"value": "TaskName"
Example for Values:
"value": "string"
"value": 10
"value": 1.2
You need to remove the last ;
Thank you
