How to reset to original size of the grid columns after increasing or decreasing the width of the grid in runtime by adjusting their columns?
In runtime, After adjusting the width of the grid it doesn't go back to initial width even after reloading the whole page. How can I resolve this?
Thanks in advance,
Shalini V.
You can use Grid Advanced widget and select Enable Grid Reset option in widget Properties.
I attached image for reference.
A similar question was asked about grid sort order. The answer to there question was that the gird did not store the initial sorting information. The same may be true for column width.
Two suggestions where made:
