Is there any sequence to import extension in ThingWorx 8.4 with Postgres installation?
(For eg: First we need to import, 1) ThingWorx-Manufacturing-Apps-8.2.2-00-extension-dependencies
2) ThingWorx-Manufacturing-Apps-8.2.2-00-extension)
Is there any sequence in 8.4?
Thanks in advance,
Shalini V.
One thing I overlooked when I first read this post. You must install ThingWorx Manufacturing Apps 8.4.x if running ThingWorx 8.4.x. The order of import will be:
Please let us know if you have any issues.
--Sharon
Hello Shalini,
Thank you for posting to the ThingWorx Developer Community.
Per the Import section on page 7 of the ThingWorx Manufacturing Apps Setup and Configuration Guide. The "ThingWorx-Manufacturing-Apps-8.2.2-00-extension-dependencies" should be imported before "ThingWorx-Manufacturing-Apps-8.2.2-00-extension".
Tyler Misner
ThingWorx Technical Support Engineer
--Sharon
Prior to installing ThingWorx Mfg Apps extension, you will need to import the ThingWorx Remote Access Extension. If can be found here:
Please let us know if you have further issues.
--Sharon
