state panel doesn't exist in the Runtime screen
MervinNobelRaj
6-Contributor
Hi Team,
I am facing an issue in that state panel doesn't exist in the runtime. The widgets in the state panel does not show it.
I have attached the Design time and Runtime Screen Shot with Log.
The Error Message Shown in the runtime
ERROR - TW.Runtime.Workspace.Mashups.getWidget exception loading widget { name: Error, message: statepaneldoesn't exist }
Mervin
7 REPLIES 7
Hi @mervinnobelraj.
The statepanel widget appears to be custom.  If this was designed by someone within your company, you may need to track down the source to determine the proper use and configuration.
--Sharon
Hi @slangley
This widget i have downloaded from the ptc support Portal and it was developed by the ptc.
Hi, State panel are tricky one. I too faced issues with them, if I remember correctly when state panel render on UI they basically have 0 height and 0 width. To resolve this issue and see state panel on UI you must play with CSS if your state panel has id 5.
#root_pagemashupcontainer_statepanel-5
width : 500px;
height: 400px;
I believe it will definitely work.
Regards
Shyam
Hi @BABA-SHYAM ,
I have tried that CSS code you have shared but in the Html hierarchy itself I can't find that element of the state panel for reference i attached the screen shot.
Mervin
I believe state panels are the default widget which you don't need to install. Actually I was talking about state widget which are default in thingworx and the version which I was working with was 8.4 where I found such issue.
Regards
Shyam
Hi @mervinnobelraj.
Which version of ThingWorx are you running?  When did you download the State Panel widget?
I checked when you first posted this topic and could not find the State Panel widget on the PTC Support downloads page nor on the PTC Marketplace.  I also found nothing in the Help Center about it.
--Sharon
Hi @mervinnobelraj.
Since the State Panel widget you have installed is apparently not available any longer, we have no information on which ThingWorx versions it is compatible with.  What version of ThingWorx are you running?
--Sharon
