Hello ,
In a responsive mashup how to add margin to a link
I want to display the forgot password link in right side (in responsive way).
but it is coming in center.
I think there are some different alignment settings, so first make the link area its own separate layout section, then in the properties i believe you can set the alignment.
if all else fails I think you might be able to override it otherwise with css
