tomcat and PostgreSQL server couldn't restart option show in services app , that restart not completed how to move next step of Thingworx installation..
pls consider and reply me....
Hi @veerasekar ,
We need more information about the issue.
What versions are used? what documentation did you follow? etc
Any logs?
You can report a support case as well.
Avihu.
[posted at the same time as response above]
Hi @veerasekar,
If this is a new installation, please make sure to follow the installation steps from our documentation for ThingWorx with PostgreSQL on Windows ?
At which step are you facing an issue ?
If my understanding is correct you are starting the Tomcat service and but it is shutting down. Are any ThingWorx logs getting created under <thingworx_home>/ThingworxStorage/logs ?
Please provide available Tomcat logs(<tomcat_home>/logs) and ThingWorx logs.
Charlotte
net stop <service name> and net start <service name>
or
sc stop <service name> and sc start <service name>
Hi all,
In Tomcat8.5.23 server running time,
i could use NET Stop Tomcat8 is working...After that I could Start NET start Tomact8 is Not work ..
in this condition i could n't restart Tomcat server...
any other method Is there..
please consider me.sir
Regards
veerasekar
Please share tomcat logs
