Why trace logs are not coming in monitoring logs. Then what is the use of trace logs ?
If I am using logger.trace("Hi there!") it is getting displayed in the ScriptLog as trace. Have you set your Log Level (see "Configure" Button in the Logs section) to "Trace/All" before you logged your messages? If you change it afterwards, your messages will not be shown because there are not logged.
