Hi ,
The method updateProperty is a callback method for a customized widget , it works if bind a Thing's service result to a field .
However , it does NOT work if bind a dynamic ThingTemplate service result, updateProperty is not call in this case . Is this a bug ?
Sean
My mistake, the EntityName is not bound. updateProperty works well after fixing it .
