Hi all,
I have a question about mashup's resolution. What happens with me it is the follow:
When I open my mashup in my smartphone it does not adjust automatic in the screen.
I am using the mashup of type "responsive (advanced)"
Regards.
Please try the following steps and see if it helps to resolve the issue:
Best regards,
Rajesh.
Thank you for your answer.
I did what you said and I was able to observe that in android smartphone it worked but in IOS no.
Have you ever been through this?
Thanks for trying it out and letting me know how it went. I did not face this issue before. I would like to you try creating a mash up with Responsive layout (not responsive advanced) and see if you face the similar issue on IOS. Please not that all the containers that you embed inside the layout should also be responsive.
I would also like to know if you are using the same type of browser from Android and IOS device to navigate to ThingWorx. Please try using the same browser and see if helps.
I used the same browser (chrome).
I will try to use the mashups type just responsive (like you said before).
