write csv is not supporting Japanese characters
abhiramk
11-Garnet
I am having things with property values in Japanese characters. When I'm trying to write that to csv using write csv function property values are not coming properly in csv file. Do write csv service support Japanese characters?
Any workarounds to handle this? PF attached screenshot for output file content. Thanks!
-Abhiram
anarwal
(To:abhiramk)
@anarwal  Thank you for your response. I have already set the encoding property in setenv file, but still issue persists.
Hi @PaiChung
Any workarounds to handle this issue in code?
PaiChung
22-Sapphire I
(To:abhiramk)
Most likely the encoding is not being honored in the actual Write CSV service.
I would submit this as a bug.
