I am having things with property values in Japanese characters. When I'm trying to write that to csv using write csv function property values are not coming properly in csv file. Do write csv service support Japanese characters?
Any workarounds to handle this? PF attached screenshot for output file content. Thanks!
-Abhiram
Hi @abhiramk https://www.ptc.com/en/support/article/CS224103 could you try this.
@anarwal Thank you for your response. I have already set the encoding property in setenv file, but still issue persists.
Most likely the encoding is not being honored in the actual Write CSV service.
I would submit this as a bug.
