Hello All,
I want to implement SSO on Thingworx(navigate) on Azure Cloud. How should I do that and what are the necessary things I need to configure and where to configure, and all details I need. Any documentation which explain clearly other than PTC docs.
KSM
Take a look:
Hi Vladimir,
Thanks for reply,
The link you have provided that shows the configuration of SSO through Ping federate, I need how to configure SSO on AD Azure. and also tell me is PingFederate mandatory for the configuration of SSO.
KSM
Hello KSM,
as of Navigate 9.5 Azure AD is also supported and documented. See
Was a bit tricky to configure the Windchill side as well.
best regards,
Stijn
