How to implement Single Sign on for Thingworx (navigate )on azure
KSM
Hello All,
I want to implement SSO on Thingworx(navigate) on Azure Cloud. How should I do that and what are the necessary things I need to configure and where to configure, and all details I need. Any documentation which explain  clearly other than PTC docs.
KSM
3 REPLIES 3
VladimirN
24-Ruby II
(To:KSM)
Take a look:
KSM
(To:VladimirN)
Hi Vladimir,
Thanks for reply,
The link you have provided that shows the configuration of SSO through Ping federate, I need how to configure SSO on AD Azure. and also tell me is PingFederate mandatory for the configuration of SSO.
KSM
sderoose
(To:KSM)
Hello KSM,
as of Navigate 9.5 Azure AD is also supported and documented. See
help center
Was a bit tricky to configure the Windchill side as well.
best regards,
Stijn
