HI ,
I have installed thingworx on windows machine connecting to Azure SQL. I get below error in scrrenshot. Upon checking through the KB i didn't linsence file gnereated . I see F:\ThingworxPlatform\licenseRequestFile.txt . Can you please help set up .
Below are the error in Application log file
Hello @VO_10604158
The error indicates that the instance of Thingworx does not have a license. The information in the F:\ThingworxPlatform\licenseRequestFile.txt file is the device ID. If you go to License Management, in the ThingWorx / ThingWorx Navigate / Windchill section.
"Select a Product": ThingWorx 8.1+ or Navigate 1.6+
"Enter Device ID": <value from licenseRequestFile.txt>
Hope that helps.
Pehowe
Hello @VO_10604158
Hope that helps.
Pehowe
I didn't have access to generate Key manully, worked with PTC support and was able to download license file.
