Issues with login
Guest
Issues with login
I have issues at login. I'm the primary admin and can assess the admin center without issues.
When I try to login in the app I get the error message: "Something's not right. Please try again. Invalid email address". I've tried to reset my password, which was successfull but I still can't log in.
Could you please check?
Thank you.
Re: Issues with login
Hi @Sally
Can you PM me the email address you are using for your Chalk account so that we can check internally?
Thanks!
in the meantime I've figured out, that it is working when I switch off the WLAN. So there is something in the company settings that prevents the logon in WLAN.
It is working fine with mobile connection. I guess this is supposed to be that way?
Or can you give me a hint on what I need to check in WLAN settings?
Thank you.
See this community post for connectivity requirements & suggested settings: https://community.ptc.com/t5/Vuforia-Chalk/Firewall-Settings/m-p/627123#M118
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
