Hi!
Do we have a specific command to lock the screen in Vuforia View on Hololens during viewing the procedure from VEC?
Any other options are available in View app? Can I switch between steps? Hoq I can exis the procedure and come back to the scan mode?
How I can get place new location in the procedure? Should I than connect the Hololens again to the PC? Or would the location be automatically updated? Would I get notifiaction in the Editor that location was changed?
Br
Olena
Hi @oparfon,
1) What do you mean by "lock the screen" and why do you want to do so when viewing the procedure?
2) You can use voice command "Next Step", "Previous Step" to navigate within the procedure
3) You can use voice command "Hey View, Scan" to exit and return to scan mode
4) For placing a new location, as far as I know you cannot update the location in Vuforia Editor, you will need to recapture and place a new location using Vuforia Expert Capture for HoloLens
Br,
Tony
