Image Dimension for Procedure in Vuforia Expert Capture
  • April 7, 2022
  • 2863 views
What is the min and max dimension size being imported into Expert Capture to prevent it from being cut off in the step of the procedure or title slide? @tmccombie
Best answer by tmccombie
@GO_9986537 Are you experiencing image cut-off issues within Vantage on mobile or View on HoloLens/Realwear devices? Is it possible to share a screenshot of the issue?
tmccombie21-Topaz IAnswer
@tmccombie Thanks its already been attended in a PTC case #16338637
Hello, could you please share the resolution? Thanks
