2D widget scrolling broken in 3D view?
SS_9894571
Hey I did some testing with datagrid that has a lot of data.
If I make a new 2D view and put the datagrid there, the scrolling in datagrid works.
If there is 3D view behind the 2D GUI then the scrolling doesn't work in datagrid.
I tried putting the datagrid into panel, card, popup and straight to the root of 2D Overlay but the scrolling did not work in any of these test cases.
I assume the 3D view captures the scrolling event?
I set the 3D Container visibilty to hidden but that did not change anything.
The scrolling didn't work with list either.
I tested with Vuforia Studio 9.0.3.
2 REPLIES 2
@SS_9894571 , could you upload your experience project for check?
This is true. Scroll widgets cant be scrolled on 3d Layout. You can fix this by placing this scroll widget inside Popup widget 🙂
