Hi Gurus,
Following Article CS325947, I was able to import my 3D model (obj) with its texture (defined by mtl file), as shown. However, after I published my project and view the model in View experience (through spatial target), the texture is not able to display properly (as shown). How do I go around this issue? Is there anything I missed out?
3D model with texture displayed properly in Vuforia Studio
Texture is not displayed in View
This seem to be the answer to your issue
Basically you have to resize the texture to make it smaller.
Thanks! It is the exact solution I was looking for! 😀
