Hi, is there a way to start an animation in an experience by selecting the model or part of the model?
As an example, opening a car door by selecting the door.
Thanks.
yes James,
same as from a button you can start anything from a part / or subassembly of the model - depending on where you put the "modelitem" widget.
Martin
yes James,
Martin
Thanks Martin, that's just what I was looking for.
