I recently updated my Vuforia Studio to version 9.19.11 from 9.12, but now I'm encountering an issue. When I try to change the height of a grid row or the background color, the changes are not visible on the canvas. They only appear when I load the preview. Is this behavior expected in this version, or could something have gone wrong during the update?
It seems that other widgets are functioning correctly; it's only the grid and panel widgets that are problematic. I've already tried reinstalling, rebooting, and using another browser (Edge).
Hi @Christian_Ll ,
I do not think that this is desired behavior, especially this was working in older version. I checked on simple project and I think I could reproduce the problem as you reported:
I will check with Studio R&D team this issue. Thanks!
Reported the issue to PTC R&D team as Jira Ticket VTS-1955. When there are further information or feedbacks to the issue/ticket from the PTC Vuforia R&D team , then I will share that in this communtiy topic.
Hi @Christian_Ll , the developer contact me today , dev cant reproduce the issue with the latest version , so far I understood the message on mac. I need information to provide to dev team:
I would appreciate your feedback! Thank you!
Hello @RolandRaytchev ,
Another project I made looks like this:
Hi @Christian_Ll,
thanks for the feedback. Now checked with R&D team and they tested with the dev 9.20 version which I think is the next version. I had downloaded internaly and installed. With the 9.20 Vuforia Studio version Iwas not able to reproduce the issue any more. So possibly we have a fix with 9.20. Please, check when the 9.20 release is for PTC customers availible - this month I believe and validate if this is solved. I think it should work but I would appreciate your feedback. Thank you!
