Click Event on Video Widget
mn1
Hey there,
Is there a possiblity to catch the click event on a video widget? If I catch all click events how can i get the ID of the widget which is clicked?
Thanks for help.
mn1
(To:mn1)
I solved the problem alreay by myself!
6 REPLIES 6
mn1
(To:mn1)
What was your solution?
mn1
(To:ClayHelberg)
I added an Event Handler:
window.addEventListener('click', $scope.Ausgabe);
and in the function Ausgabe I checked, if the click Event was sendet by a Video:
$scope.Ausgabe=function(){
console.log("A click event is recived");
if (window.event.path[0].tagName=='BUTTON'|| window.event.path[0].tagName=='IMG'){
console.log(window.event.path[2].attributes["0"].nodeValue); // if an image or button was clicked, this line prints the id
if (window.event.path[0].tagName=='VIDEO'){
console.log(window.event.path[3].attributes["0"].nodeValue); // If a video was clicked, this line prints the id
Excellent, thanks for the explanation.
Hi @ClayHelberg ,
here I want  to clarify it furhter based on my experience.
So in the @mn1 's example the solution is based on particular windget configuration and will not work and every project - so need adoption in particular situation . So I did an example and it the code was not working in this case. So to get it working I needed to go in chrome in the  console debugging  Strg -Shift -I and  do some thing like:
document.addEventListener('click', function(event) {
console.log("click() 1 called");
 console.warn(event);
And then to check the console warning in the console window and to try to explore the current setting of the event object:
In my case for the video widget  the correct expression should be:
console.log(window.event.path[0].attributes["0"].nodeValue);
 // If a video was clicked, this line prints the video source
Thanks for the elaboration, @RolandRaytchev . That will be helpful info to file away for future reference.
