Hey,
according to this, it is not possible to connect the trial version of Vuforia Studio with the trial version of ThingWorx.
Is this correct?
Thank you
@Rapha97 Yes, that is correct. Studio trail comes with an integrated ThingWorx trail associated with it which could be used however that instance has some restrictions & limits.
-Durgesh
Thank you.
Where can I find those restrictions & limits?
@Rapha97 You can log in to the Trial portal - https://trial.studio.vuforia.com/home/ and in the center, there is a Studio Getting started guide which has details. I am also sharing the direct link if that helps- https://s3.amazonaws.com/studio.thingworx.com/documents/StudioGettingStarted_Trial_en.pdf
-Durgesh
On page 6 it says: "Access to ThingWorx is included with the Vuforia Studio trail."
Can I connect with this ThingWorx to the Azure-cloud or a copy of the cloud data?
Thank you
