For a Project I need to control a Relay connected to a Raspberry Pi.
So using the Get Request in a Python script and just changing the value of the Property was rather slow. How would you solve this problem?
@Gaschtae You will have to use ThingWorx SDK ( Java, C, EMS) and write a service which can be called on click of button in ThingWorx Studio to perform the required action.
For more details on Edge SDKs check out the Help center documentations.
-Durgesh
