Hello Everyone
I have a mıtsubıshı automation education set which consist of servo motors-drivers, asynchronous motor and I want to create an Augmented Reality application which shows motors rpm and errors but I am not sure how to do this.
I have a work-flow like this;
First I have to connect this set to IOT gateway via ThingWorx Industrial Connectivity so I can able to reach motors rpm data and errors.
And to show this data(motors rpm and errors) in my Augmented Reality application I think, I should use Vuforia Studio.
Are these steps right?
Thank you for all respons.
@RAMO Sorry for the late response, yes you will have to first connect to your IoT Gateway via ThingWorx to get real time data which could be then used & integrated with your AR 3D content inside Vuforia Studio application.
