Edit CSS Styles with JavaScript
Jonny
9-Granite
I tried to cange the CSS Style with JavaScipt code but it does not work. What is wrong?
$scope.ShowClass = function() {
    document.getElementById('classname').style.display = "block";
$scope.HideClass = function() {
    document.getElementById('classname').style.display = "none";
1 REPLY 1
Unfortunately, stylesheets don't work that way. The most direct approach is probably to identify the desired elements and modify their styles directly, something like this:
$scope.ShowClass = function () {
    var elems = document.getElementsByClassName('classname');
    for (var e in elems) {
        elems[e].style.display = "block";
and similar for $scope.HideClass()
If you really need to modify the class style rules, rather than just changing the styling of affected elements, you might find some useful information here:
https://www.quirksmode.org/dom/changess.html
--Clay
