Error while debugging Vuforia Studio Project with Javascript
  • November 5, 2019
  • 2 replies
  • 5586 views
Good morning,
while I was trying to debug and run my Vuforia Studio Projekct with Javascript, this error popped up (see studio_error). Also the console from Google Chrome showed me this (see Error_console).
I was trying to read from an inputfield and paste it to the console. Actual I want to read from an .txt File, but in this step, I just want to have the output in the output text field.
This is my Javascript:
$scope.einlesen = function(){
var inText = $scope.app.view['Startseite'].wdg['textInput-1'].text; //Text aus dem Inputtext holen und in die Variable inText speichern
console.log("Eingelesener Text: ", inText);
I call the function when clicking on a button.
Furthermore: Is there no documentation for $scope, $element, $attrs, $injector, $sce, $timeout, $http, $ionicPopup, and $ionicPopover, how to use them, or a general documentation for Javascript with Vuforia Studio, because using "normal" Javascript result every time in a crash, so I have to end the process and restart Vuforia Studio.
Thank you for your help.
PS: Any clue how I can learn the programming languange?
Best answer by ytella
Hi @Rapha97 ,
I have updated the code as shown below and was able to see the text input displayed on the console:
var inText = $scope.view.wdg['textInput-1'].text; //Text aus dem Inputtext holen und in die Variable inText speichern
Please review the below community post for some angularJS documentation:
https://community.ptc.com/t5/Vuforia-Studio/What-kind-of-framework-does-Vuforia-Studio-use-Angular/m-p/622985
Rapha971-VisitorAuthor
Here the error from chrome
ytella17-PeridotAnswer
Hi @Rapha97 ,
Thank you for your answer.
Unfortunately this was the wrong code. That code worked fine.
I was trying to read from a .txt File with a "normal" Javascipt, wich I found here (https://stackoverflow.com/questions/14446447/how-to-read-a-local-text-filehttps://social.msdn.microsoft.com/Forums/en-US/64ea2d16-7594-400b-8b25-8b3b9a078eab/read-external-text-file-with-javascript?forum=sidebargadfetdevelopment). After replacing "file" with the var filePath = "file:///..." and deleating
rawFile.send(null);
 I get the warnin (see attachement). WithrawFile.send(null); I get the errors (see attachement).
Hi @Rapha97,
Here is one of the examples to read text from a text file and assign the data to textInput widget.
  • Upload the text file under Project panel -> Resources as shown below:
  • Create an application parameter with any name such as 'TEXTContent' and bind it's value to 'Text' property of the textInput widget as shown below:
  • In Home.js, please write a function similar to below code:
    • $scope.readTextfile = function()
      var httpRequest = new XMLHttpRequest();
      var myFile = httpRequest.open('GET','app/resources/Uploaded/myfile.txt', true)
       $http.get('app/resources/Uploaded/myfile.txt')
       .success(function (data) {
       $scope.app.params['TEXTContent'] = data;
       .error(function (data, status, headers, config) {
       // Do some error handling here
  • Call the above function under the click event of a Button widget
In my text file, I have the contents 'Hello World!'. When I click on the Button the 'Hello world!' is displayed on the textInput widget as shown below:
Hope this helps!
