External Data - Date&Time format
Hello friends
I need to display data in Chart from static time interval but I cannot solve how to correctly write startDate and endDate.
Can you help me?
Thanks for every respond.
Tomas
Hello friends
Can you help me?
Tomas
Hi
I think this is issue with the converting of the correct data format. Your argument/parameters here are strings what the QueryNumberPropertyHistory service seems not to "like"
So my suggestion is to create a TWX service where you will convert / parse the string
Example:
so here the code of the TWX service - input parameters max and min as strings.
var params = {
oldestFirst: false /* BOOLEAN */,
maxItems: 600 /* NUMBER */,
propertyName: 'sensor' /* STRING */,
endDate: undefined /* DATETIME */,
query: undefined /* QUERY */,
startDate: undefined /* DATETIME */
params.endDate = parseDate(max, "YYYY-MM-dd HH:mm:ss.SSS Z");
params.startDate =parseDate(min, "YYYY-MM-dd HH:mm:ss.SSS Z");
// result: INFOTABLE dataShape: "NumberValueStream"
var result = me.QueryNumberPropertyHistory(params);
Then in Vuforia Studio we need to add e.g. the TestTing custom service getChartDataMinMax
And we can test then in the preview:
No account yet? Create an account
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
