External data datetime format
  • April 30, 2021
  • 2198 views
Hi everyone,
I've created a "thing" with a property named ExpirationDate with a basetype of DateTime.  I the date displaying in an experience.
The issue is the date displays as "2021-04-30T21:54:03.225Z".  Is there a way to change the format so the data appears as month/day/year(e.g. 4-30-2021)?
Thanks in advance.
Best answer by dsgnrClarK
It can be accomplished by Instance methods
Add below to filter
return value.getMonth() + 1 + "/" + value.getDate() + "/" + value.getFullYear()
Add below to filter
JL_1834612-AmethystAuthor
Thanks for the response.  You mention to add it to the filter, but what filter are you referring?  I don't see a filter in either composer or Studio.
thanks
