Hello everyone!
I am having some problems with publishing an AR-Experience which is connected to a ThingWorx Thing of mine.
I created the Experience and copied the URL of my ThingWorx into the experience Server field.
I was able to add the Thing after I logged in with my Administrator login from ThingWorx in the External Data column and connected its property to a 3D-Label which displays the value correctly.
In the Infotab the IP-Address is also correctly Displayed but when I try to validate it an Error Message occurs which says: Failed to authenticate experience server.
And when I try to Publish the Experience it displays following Error message:
Uh-oh! Publish failed. Check the log for errors.
Not Found.
My log shows following message:
[12/21/2017 14:42:28] info: [twx-studio:projectHelper] Building ves-ar-extension app: Test
[12/21/2017 14:42:29] info: [twx-studio:index] Notify preview windows: private-room-Test
[12/21/2017 14:42:29] [0mGET /api/switch [32m200 [0m0.181 ms - - [0m
[12/21/2017 14:42:29] [0mPOST /api/publish/ [33m404 [0m2.946 ms - 42 [0m
Many thanks in advance!
Lars Peuckmann: Could you please confirm if you are facing issue with your Trial Studio instance or have setup your On-premise Experience Service ?
Request you to please share complete studio log to review and assist.
-Durgesh
Hey Durgesh,
I am facing these problems with the trial version.
I downloaded the ThingWorx trial and the ThingWorx Studio trial seperately, could this cause a problem?
Added to this post you will find my whole studio log.
Thank you in advance
