File Driver in iOS
gi395923
2-Explorer
File Driver in iOS
Hi .
I am trying to create file driver for iOS Platform , After following document i am able to generate build, i found that Driver.h file is missing in VuforiaSDK  for iOS. this is blocking us going forward in implementation.
Can you Please help me on this.
Thanks in Advance.
Hi @gi395923 ,
I do not think that this is the correct community for this quesiton / (or at least it is not yet)
So far I know
The functionality  of the Vuforia SDK is directly supported  on the Vuforia Developer portal
The  Support portal – the Support center:
https://developer.vuforia.com/support
And the support forums :
https://developer.vuforia.com/forum
In the Forums  you can directly report a problem with the Vuforia SDK -> create a new Topic for your issue
So I think this should be the correct area for this particular problem: https://developer.vuforia.com/forum/ar-technical-discussion/android
For  Vuforia Engine issues could be reported on the following link /PTC Web Page:
https://developer.vuforia.com/support/contact/cloud
Of course if some community member has experience in this matter is wellcome to help.
Hi @gi395923 ,
So far I know
