Geting Model Position
AlexK
Dear Community
I've found some code to get the position of an assembly part here:
https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center/cad_structure_api.html
But it doesn't seem to work for me
$scope.centerof = function() {
// Get the Structure information for model-1
  PTC.Structure.fromId('model-1').then ( (structure) => {
      // Get the properties of the 'model-1' widget
      var widgetProps = $scope.view.wdg['model-1'];
      // Get the bounding box information for part '/0/0/2'
      var bbox = structure.getBounds('/0/0/2');
      // Transform the bounding box to account for the 'model-1' widget's location
      var xform_bbox = bbox.transform(
          [widgetProps.x, widgetProps.y, widgetProps.z],
          [widgetProps.rx, widgetProps.ry, widgetProps.rz],
          widgetProps.scale);
      // Move '3DImage-1' to the center of the bounding box
      $scope.view.wdg['3DImage-1'].x = xform_bbox.center.x;
      $scope.view.wdg['3DImage-1'].y = xform_bbox.center.y;
      $scope.view.wdg['3DImage-1'].z = xform_bbox.center.z;
      // Get the location information for part '/0/2/8'
      var loc = structure.getLocation('/0/0/2');
      // Transform the location to account for the 'model-1' widget's location
      var xform_loc = loc.transform(
          widgetProps.scale);
      // Get the rotational component as euler angles
      var rot = xform_loc.rotation.asEuler();
      // Rotate '3DImage-2' to match the rotation
      $scope.view.wdg['3DImage-1'].rx = rot.x;
      $scope.view.wdg['3DImage-1'].ry = rot.y;
      $scope.view.wdg['3DImage-1'].rz = rot.z;
I've added a demo experience to troubleshoot the issue.
Does anyone know what's wrong?
Best wishes
Alex
Hi @AlexK ,
possibly the project used old template. Also there was no meta .json file - at least I did not find such after I  imported the project to Vuforia Studio. So I  tested it ( with   Vuforia Studio 9.15)-
One point is that all the  parameter objects  should be an array from 3 items (also the scale) according to the PTC Studio Help.  so changed it e.g.:
      console.log("bbox")
      console.warn(structure.getBounds('/0/0/2'))
      posArr=[]
      posArr.push(widgetProps.x);posArr.push(widgetProps.y);posArr.push(widgetProps.z)
      rotArr=[]
      rotArr.push(widgetProps.rx);posArr.push(widgetProps.ry);posArr.push(widgetProps.rz)
      scArr=[]
      scArr.push(widgetProps.scale);posArr.push(widgetProps.scale);posArr.push(widgetProps.scale)
      var xform_bbox = bbox.transform(posArr,rotArr,scArr);
So now  it seems to work. Here the modified project attached to the post.
I think to get the (new ) functionality to work you need to start  with the latest version and create a new project. I did not  see this functionality  before. Because I remember that in previous    versions we needed to use an TWX extension to extract the bbox data . I remember that such requirement was reported as enhancement to R&D Team and now is really  good to know that it is already implemented in the current functionality !
4 REPLIES 4
Hi @AlexK ,
      console.log("bbox")
      posArr=[]
      rotArr=[]
      scArr=[]
AlexK
(To:RolandRaytchev)
Hi Roland
Thank you very much, your version works great! I did have to update my studio version to make it work.
Best wishes
Alex
further looking in the meta .json file -the bounding box information could be found there ... here a part of blu_pump.metaddata.json:
,"Part Name":"93G824.PRT","Part Path":"Illustration/BOBCAT_S185.ASM/6725314.ASM/93G824.PRT"},"__StructureProperties":{"Bounds":{"min":[0.5037899613380432,-0.07964058220386505,0.18049299716949463],"max":[0.5228399634361267,-0.060590580105781555,0.23129300773143768]},"Location":[-1,1.2246467991473532e-16,-4.493862367303331e-16,0,-4.493862367303331e-16,-6.123233995736761e-17,1,0,1.224646799147353e-16,1,6.123233995736766e-17,0,0.513314962387085,-0.0701155811548233,0.21859300136566162,1]}},"/0/0/4":{"__PV_SystemProperties":{"Child Count":"0","Component Name":"93G824.PRT","Display Name":"93G824.PRT","Model Extents (mm)":"50.8","OL File Name":"ldemo_0_bobcat_s185_asm_181.ol","Part Depth":"4","Part ID":"4","Part ID Path":"/0/0/4","Part Name":"93G824.PRT","Part Path":"Illustration/BOBCAT_S185.ASM/6725314.ASM/93G824.PRT"},"__StructureProperties":{"Bounds":{"min":[0.6162821650505066,-0.04949839040637016,0.18049299716949463],"max":[0.6353321671485901,-0.030448388308286667,0.23129300773143768]},"Location":[-1,1.2246467991473532e-16,-4.493862367303331e-16,0,-4.493862367303331e-16,-6.123233995736761e-17,1,0,1.224646799147353e-16,1,6.123233995736766e-17,0,0.6258071660995483,-0.039973389357328415,0.21859300136566162,1]}},"/0/0/5":{"__PV_SystemProperties":{"Child Count":"0","Component Name":"93G824.PRT","Display Name":"93G824.PRT","Model Extents (mm)":"50.8","OL File Name":"ldemo_0_bobcat_s185_asm_181.ol","Part Depth":"4","Part ID":"5","Part ID Path":"/0/0/5","Part Name":"93G824.PRT","Part Path":"Illustration/BOBCAT_S185.ASM/6725314.ASM/93G824.PRT"},"__StructureProperties":{"Bounds":{"min":[0.586139976978302,0.06299380213022232,0.18049299716949463],"max":[0.6051899790763855,0.08204380422830582,0.23129300773143768]},"Location":[-1,1.2246467991473532e-16,-4.493862367303331e-16,0,-4.493862367303331e-16,-6.123233995736761e-17,1,0,1.224646799147353e-16,1,6.123233995736766e-17,0,0.5956649780273438,0.07251880317926407,0.21859300136566162,1]}},
Here example for  "Part ID Path":"/0/0/5","Part Name":"93G824.PRT"
AlexK
(To:RolandRaytchev)
Just tried it in another experience, and had to upload (generate metadata.json file) the model again, to make it work. it seems like the new version of studio has a different metadata generator, which enables the bounding box function. just as info for anyone else trying to use this.
