How do I delete a published expierence from the server?
wrsamuels
I have a published expierence I want to delete.
I tried to write over it but it just adds experiences to the same mark.
katte
(To:wrsamuels)
William, technically Ankit's answer shall delete the project in the cloud as well.
As an alternate way, you can try using CURL or Postman to make a delete request. The Curl command should look like:
Curl -u <user>:<password> -H "Content-Type: Application/JSON" -X "DELETE" https://<your-domain-name>/ExperienceService/content/projects/projectname
-Giri
5 REPLIES 5
William Samuels​,
In the ThingWorx Studio Project page; you will find a Cloud icon with a cross; you can use this link to un-publish your project from the Experience server.
I hope it helps.
Ankit Gupta
wrsamuels
(To:ankigupta)
The project has been deleted from the surface, and the ones I see don't have a cloud icon.
what I can see is if I go to the server I can find the project and view the source code, but cant edit it or delete it.
what should I do to either edit or delete it?
I did see another thread that stated to use another piece of software, but would rather stay in this one.
Thanks for the quick replies.
wrsamuels
(To:wrsamuels)
Still stuck with an item I cant remove from the server.
katte
(To:wrsamuels)
-Giri
wrsamuels
(To:katte)
Having deleted the project and not noting the name, Thingmark and other data led me down a road to have to learn a little CURL, which worked as you suggested for projects I knew the names of. Not being able to see a list of items under my name was frustrating.
I got lucky on guessing the name of the last one.
The community worked, it got me to a point of being able to create and manage experiences, thanks everyone.Unpublishing Experiences from Server
earlier I stated I could not see the cloud icon, that was due to an explorer issue, since resolved.
