How do I delete a published expierence from the server?
  • February 28, 2017
  • 4396 views
I have a published expierence I want to delete.
I tried to write over it but it just adds experiences to the same mark.
Best answer by katte
William, technically Ankit's answer shall delete the project in the cloud as well.
As an alternate way, you can try using CURL or Postman to make a delete request. The Curl command should look like:
Curl -u <user>:<password> -H "Content-Type: Application/JSON" -X "DELETE" https://<your-domain-name>/ExperienceService/content/projects/projectname
-Giri
William Samuels​,
In the ThingWorx Studio Project page; you will find a Cloud icon with a cross; you can use this link to un-publish your project from the Experience server.
I hope it helps.
Ankit Gupta
wrsamuels14-AlexandriteAuthor
The project has been deleted from the surface, and the ones I see don't have a cloud icon.
what I can see is if I go to the server I can find the project and view the source code, but cant edit it or delete it.
what should I do to either edit or delete it?
I did see another thread that stated to use another piece of software, but would rather stay in this one.
Thanks for the quick replies.
katte5-Regular MemberAnswer
-Giri
